Lester,
As mentioned here and in the other thread, bonding to finish paint isn’t a good idea, so you’d want to either mask off the epoxied flange areas on both the bonnet and the brackets prior to finish paint, or sand off the finish paint prior to bonding. Neither is a very good option.
Here’s what I did…
Epoxy primed the ducts, headlight panels and bracketry.
Masked the bonding surfaces on the bracketry.
Finish painted the ducts (inside and out), the headlite panels, and the mounting bracketry.
Epoxy primed the underside of the three bonnet sections and the chin section.
Finish painted the interface surfaces of the bonnet (a little over spray onto the outside surface was sanded back by the body shop/painter.
Assembled the sheet metal shell.
Attached the empty shell to the tub/frame and adjusted it to fit. (R & R Twice )
Removed shell, flipped over, and trial fit ducting, headlight panels and radiator rock guard with flanges bolted in place.
Masked along the edges of the flanges and along outer edges of the ducting (to define the area that would be difficult to reach with the ducts installed).
Removed the ducting/bracket assemblies/headlight panels and separated the brackets from the sheet metal.
Lightly sanded the epoxy on the bonding surfaces (bonnet and the brackets).
Bonded the brackets to the bonnet. Pulled the masking tape when the Sikaflex was beginning to set.
Color painted the underside of the fenders and center section that would be masked by the installed ducting.
Installed the ducting, headlite panels and stone guard to check for fit.
Removed and rebounded one flange because I didn’t like the alighnment. (A real chore).
Installed the assembled bonnet to the tub/front frame assembly one last time.
Removed and placed on the bonnet dolly.
Masked the ducts and areas of fenders that were finish painted.
Finish painted the underside of the center section to include the visible edge of the Sikaflex.
Took the bonnet to the painter on it’s own dolly where they did finish body work and painted…separate from the body. Climate controlled paint booth. Doors and boot lid were also painted separately. Zero issues with paint match (OP Gunmetal). That said, my painter is a magician.
Prior to wet sand…
Bonnet dolly
