right rear tail and brake light fault
Welcome to the forums.
Your post is a bit cryptic, I take it you have checked the obvious and the bulbs are OK?
I am not too sure if the ‘S’ types have modules for each corner?
right rear tailight and brake light failure neither of them light up left sise is all good,cheers fred
Did you try the right side bulbs in the left side sockets, and vice versa?
After swapping bulbs side to side, if right side still doesn’t work, then check for +12V at right side sockets.
Just starting with the basics.
After that, start with the wiring schematic to find out where to trace the wires back to.
I would next go all the way back in the schematic, if still no +12V on those wires when there should be, whatever is upstream is the fault.
If +12V at that point, then its something/someplace between there and the sockets, which could get time consuming to patiently trace down.
I have checked the fuses all good what is shemantic Cheers Fred
Electrical wiring diagram.
Any updates
