I am working on a friend’s 1988 XJ40 after a multi-year outdoor storage (6 - 8 years of sitting idle outside) and I am unable to get the fuel filler door to open. I tried pushing or pulling the small white lever inside the trunk that is under the filler door solenoid assembly but this does not accomplish anything. I replaced the fuse that is near the underside of the filler door and I have looked at the power on the various pins in the gas door relay socket. Today I tried spraying a lot of penetrating oil under various parts of the fuel filler door edge. I do have power on one leg of the fuse socket when I remove the fuse and check with a VOM.
BTW, I was told that the fuel door is supposed to release if you push down on it for two seconds. When I tried this the fuel door does not move when depressed. I.E. When I push down on the fuel door, there is no downwards movement at all.
Any other suggestions would be most welcome.
