I have a 1968 V8 250 with a four-speed and overdrive. I replace the two front engine I have a 1968 V8 250 with a four-speed and overdrive. I replaced the two front engine mounts, and the transmission mount rubbers. I also ordered the part for the middle motor mount, but I’m not certain precisely how it is supposed to be adjusted.
When I found it, The nut was loose, meaning the shaft could slide around in the mount. Is this supposed to be tightened down? I can only assume so. If anyone can provide some details, that would be wonderful.
Nope. Scratch that. I had to loosen it up from the fully snuggled up position because the yoke at the front of the driveshaft was fouling the transmission tunnel. Seems odd to me, given that the front mounts are new. Has anyone else encountered this?
It needs to be in a neutral position, i.e. when the engine and trans mounts have the weight then you bring the lower bush up to rest underneath the cradle and then snug down the top bushing screw.
Thanks, Robin, but the only way to bring the lower part into contact with the mount is to snug the top down all the way, which causes the driveshaft to foul the tunnel.
Are there supposed to be shims under the front motor mounts? My working hypothesis is that the engine and trans pivot around this middle mount. Since the rear of the transmission is too high, it would follow that the front of the engine is too low, and it’s not due to collapsed mounts, as I just replaced those and they look fine. Also, my MGB has shims under at least one of the motor mounts, so…?
Are you sure you have the correct stepped washer
I have just been out to the garage where my 3.4 is sitting waiting to be placed in the engine bay and confirmed that mine is threaded as per this item;
I’m going to have to remove the rod and free the washer, it seems. I did find the instructions in the manual, in the prop-shaft section. Of course, my manual pre-dates the addition of the 4-speed with overdrive to the options list, so things like the non-existent center bearing make interpreting the manual a bit challenging.
