Should anyone need to change their accumulator or brake switch, I did a write-up.
https://foreverxjs.godaddysites.com/xj-s-blog/f/accumulator-atrophy
Thank James - very helpful !!
Nice. Might I suggest adding that normal nitrile O-rings should not be used as they are incompatible with brake fluid?
What material o-rings should be used?
I dunno. If there’s any doubt, put a bit of brake fluid in a glass jar, drop in your O-ring, and leave it for a month. If the fluid turns dark, that’s bad. If the O-ring disappears, that’s really bad. Both things will happen with a standard nitrile O-ring. You need seals that are intended for use with brake fluid.
Here’s a pretty good write up…
https://www.pegasusautoracing.com/document.asp?DocID=TECH00147
Thanks Kirby duly noted! I never considered the kind of O-ring but its true brake fluid can be very corrosive.
