Please tell me where the choke Lever is situated in my MKV.
I’m sorry. The expression ”choking lever” is Right.
There is no choke lever on the Mark V. There is a starting carburettor located between the other two carbs. It has an electric solenoid on top which should have a 12 volts negative wire on one terminal usually coming from the coil, and the other terminal wire goes to either a thermal grounding switch on the water manifold, or may have been converted to a manual positive grounding switch located somewhere under the dashboard. Or may have been converted in some other way electrically.
Thank you for the Explanation. I rememberd in the meantime that my mechanic situated it
for my MKV. He teached me where it was in the car.
