Gary, that’s not the correct mounting spot, and I’m wondering why someone (previous owner I presume?) would drill a hole through the dash panel when the proper spot is easy to use and doesn’t put such a bend in the cable like this one would.
Brandon, check out the following thread. In the last post, John has pictures of the mounting position on the under-dash Hardura panel.
