Has anyone used a product from www.leatherique.com? The leather
seats in my XJS are a little dry and I would like them to have a
softer feel. Are there any other recommendation?–
Leerunr
Leatherique is very good. Patience is required, though. It took years for
the leather to harden. It’ll take repeat applications of Leatherique over a
period of weeks or even months to soften it. I suggest cleaning the leather
first with their “Pristine Clean” product.
I’ve also used a mixture of lanolin and neat’s-foot oil on hardened leather.
I got somewhat faster results but its rather messy.
Doug Dwyer
Longview Washington USA
1995 XJRFrom: “Leerunr” leerunr@pacbell.net
I’ve used their products for years. They have a rejuvenator oil which you
apply (rub in with hands) and allow to soak in for a few days. The oil
softens the leather but, more importantly, brings all the years of
contamination out to the surface. You then rub on their Pristine Clean with
a rag and scrub off the contaminants. Pristine Clean is what you then
continue to use periodically to keep the leather looking new. They also
sell excellent water-based dye which is very easy to apply and they can
match any color from a sample. They also sell a product to repair cracked
leather but I have no experience with it.
Pat H.-----Original Message-----
From: owner-concours@jag-lovers.org [mailto:owner-concours@jag-lovers.org]
On Behalf Of Leerunr
Sent: Friday, November 13, 2009 2:17 AM
To: concours@jag-lovers.org
Subject: [concours] Leather restoration
Leerunr
Currently using Pinnacle products with good results on some very tough
restorations with very good results. Multiple applications and patience as
Doug suggests is great advice.----- Original Message -----
Sent: Friday, November 13, 2009 3:03 AM
Subject: Re: [concours] Leather restoration
a period of weeks or even months to soften it. I suggest cleaning the
leather first with their “Pristine Clean” product.I’ve also used a mixture of lanolin and neat’s-foot oil on hardened
leather. I got somewhat faster results but its rather messy.Cheers
Doug Dwyer
In reply to a message from Leerunr sent Thu 12 Nov 2009:
I should have been more specific. My XJS received 99.6 points at
the last Jag concours. The only area I was graded down on was small
surface cracks on the drivers seat and some wear on the piping also
on the drivers seat. Other than that the leather looks like new but
does not feel as supple as the leather I had in my 1969 XKE. Will
this product soften the leather?–
Leerunr
Don’t take mine as the final word on the but my experience is that the
leather used in E-types is thinner and softer than leather used in
XJSs…sorta like a lady’s expensive leather dress gloves versus heavy,
thick leather work gloves, if ya get what I mean.
The work gloves might be in terrific condition but they’ll never feel as
soft as the expensive dress gloves.
Doug Dwyer
G’day,Leatherique will soften your seats,probably 2 or 3
applications 3 or 4 days apart,the best method I’ve used is to cover
the seats in black garbage bags to help sauna them and open the
pores. After the 3rd application clean with prestine clean,then
have them mix up the colour die to match your seats and piping mix
some die in the crack filler apply to cracks after which use the
preppi g agent and then the die it works well on the cracks and the
piping. If your seats have been recoloured before check them for
colourfastness in a not easy to see spot.
Hope this helps.
Ross–
Whispering Assassin
Glenmore Park NSW, Australia
I used products from:
http://www.lederzentrum.de/international.php.
I was really impressed with their softener oil. Initially I thought
that my seats would need complete recovering, as the leather was
like cardboard. Here are a few pics of my front seat resto:
http://picasaweb.google.de/JagWaugh1968/Seats#
They also offer a touch up dye kit, which sounds like what you
might be interested in, as it is to touch up minor wear marks and
such.
Andrew–
1968 3.8S
Zurich, Switzerland
In reply to a message from JagWaugh sent Sun 13 Dec 2009:
There is only one way to go here, it is cheap, highly successful,
and WORKS!.. purchase some neatsfoot oil from your local cobbler,
purchase some ANhydrous lanolin from any good compounding pharmacy,
Now create a 50/50 mix by warming up the lanolin in the microwave
( take the lid off the jar first!) and adding it to the neatsfoot
oil, allow the mixture to cool… you will end up with a gooey
substance that has the consistency of chicken fat. Now get the
interior of the car HOT in the sunshine and slather the bejesus out
of it on the leather, DO NOT RUB! leave it to soak for a day. now
CAREFULLY with a clean white terrytowel remove any excess. REPEAT
the procedure 3 or 4 times. THIS IS IMPORTANT. The leather will
initially darken slightly this is purely because it is wet, the
original color will return don’t worry. This process is CHEAP, IT
WORKS! AND THE MOTOR PRODUCT MANUFACTURERS DON’T WANT YOU TO KNOW!
I have used this formula on Jaguar leather since 1976 without
failure. I have also NEVER lost a single point on any interior so
treated in the entire time. best of luck.–
godfrey
pender island bc, Canada
In reply to a message from Pat Harmon sent Fri 13 Nov 2009:
Hallo Everybody,
I checked Leatherique website and the products look great.
Unlukilly bringing those products to Italy is very expensive
and takes a lot of time in customs.
Does anybody know if Leatherique is sold by any European
dealer?–
Simonone Milano (ITALY) 1972 XJ6 S1 4.2 Auto
Milano, Italy
In reply to a message from Simonone sent Wed 8 Jun 2011:
Spain might be closest. See:
http://www.leatherique.com/distribution_network/international_distri
butors.html
Good luck,
Rob–
dealer?
Robert Laughton www.leatheriquecanada.com 1999 Super 8
I have seen their add in the British Mag -Jaguar World
If you call/enauk them they would know,
Pete
“Robert Laughton” dadsfarm@computan.on.ca 6/15/2011 4:05 PM >>>
butors.html
Good luck,
Rob–
dealer?
Thank you everybody.
Bad luck struck the cat and now a gearbox overhaul is due, so
leather restoration is no longer a priority.
I saw liquid leather ad: www.liquidleather.com which looks
cheaper and easier to use (at least product explanations are
easier to understand…)
Anybody tried this brand on cracked leather?–
Milano, Italy
Why waste the $$… I will tell everyone AGAIN!.. use a 50/50 mix
of anhydrous lanolin and neatsfoot oil… works better than
anything else… is cheap, redily made and will last a long
time!..never lost a point on an interior yet!–
godfrey
In reply to a message from godfrey sent Sun 3 Jul 2011:
Is the mixture for filling the cracks, or for redyeing?–
Milano, Italy
a 50/50 mixof anhydrous lanolin and neatsfoot oil…
This is for keeping the leather soft and supple. A second product is used for filling in cracks. A third product is used for dying the leather.
Geoff Green
95 XJS 4.0 conv, 76 XJ-S, 61 E-type OTS, 05 F250 Turbo Diesel, 10 Escape
Keeping track of every Jaguar XJ-S, with your help.
http://www.xjsdata.com
3.6 XJS Register paulzimmer@btopenworld.com
Eventer Register pascal.mathieu@perso.be
Simonone,
Try contacting http://www.colourlock.ch/international.php I
used their stuff to resoften cardboard like dried out leather,
repair splits and cracks and recolor the seats on my car. I am
pleased with the results:
https://picasaweb.google.com/JagWaugh1968/Seats#
Andrew–
dealer?
1968 3.8S
Zurich, Switzerland
