I am removing parts from a '55 MKVIIM that has a JLN manual Gearbox with Overdrive
I just want to double check exactly what parts are needed for both a conversion from Auto, and Manual boxes
As per the heading, I am advised it will fit the stated models MK7-9 XK140-50
For Auto Conversion;
flywheel, bellhousing, starter ? clutch unit, clutch bottle & pipes, master cyl, slave cyl, pedal assembly, JLN gearbox, OD unit, gearbox mounts, front driveshaft, speedometer & cable, gear stick gator, overdrive switch, relay & wiring, manual gearbox sheetmetal cover panel on body, complete handbrake assembly, front seats
For 4 speed Manual cars;
JLN gearbox, OD unit, gearbox mounts, front driveshaft, speedometer & cable, overdrive switch, relay & wiring
Optional;
Can supply, centre bearing mechanism, rear driveshaft, complete rear end or diff, vehicle data plate, will supply complete NOS clutch master cylinder, clutch master & slave cylinder rubber seal kits
Did I leave anything out for a complete bolt up conversion ?
All comments welcome
