I am wondering if my spark jump problem might be due to not having the distributor in the exact correct alignment.
Is there some fairly complete documented procedure for setting the distributor orientation?
I figure the engine has to be set to TDC but I don’t actually know if there are any external pointers or marks to tell when the motor is at TDC.
Then once I have it set to TDC, is there a specific mark inside the distributor that number one plug wire should be pointing to?
The AJ6 engine has a mark on the crank damper to indicate TDC.
I would mark the dist body with the cap in situ, remove the cap and set rotor to point at that mark?
