I wondered whether it’s possible to re-route the hose to the air intake (at air-filter level, for example) to have the vapours burnt, quite simply to avoid seeing as I do once in a while, some oil vapours when standing in traffic with a warm engine.
My MG was like this, until I changed to a Weber, not really vacuum assisted, but rather just flow assisted.
“vapor” emitted from the breather pipe on an engine during the warm-up phase is normal and due to condensation forming in the crankcase if it persists after the engine is up to normal operating temperature then it is blow-by from less than ideal piston ring condition.
Which Crankcase Breather are you talking about? There’s the Silver foil tube from the Front of the Cylinder Head. Is there any other Breather? I seem to remember one when I first owned the car but it’s been 20 odd years since. Can’t seem to find it now. I had even put in a Catch Tank for it that came with the car.
That’s the only one.
Inside there is a baffle plate with two big holes. The orientation of the holes is top and bottom, not side to side, so the oil thrown up by the chain flows back down inside.
Done: I installed the breather 180° from its original position and with an invisible plastic elbow connected it about 20 cm after the air filter to the hose going to the carbs. One week now, perfect, less smells and a reduced few drips indeed…
If you’re still worried about that, absolutely not a problem. My pistons are clean with only the lightest trace of soot after ten thousand miles. I have a little bit of blowby which I feel is normal.
