Hi All
While working in the LF wheel well of my car ('53 XK120 DHC) I happened to look at the rear of the crankshaft damper and noticed that a small chunk of the rubber had obviously detached itself. After 60 odd years I suppose I should not be surprised, clearly the rubber has become brittle over time. Checking the usual sources I note that they offer units that are rebuilt and require a core charge. Has any lister actually used the services of companies who rebuild these units such as Damper Doctor and others?
Tadek, sometime back you were looking for a company to rebuild your damper as you wanted to retain the original, did you find someone and if so was it in Europe or did you, as Rob suggested, try the above named company or Winslow Manufacturing?
One thing I read from one of the sources is that the engine would need to be re-balanced after fitting their rebuilt damper. Would this be necessary if one had the original unit rebuilt? I have noticed that there are several drilled areas on my existing unit, clearly balanced at the factory. As a neophyte in this area, if one simply gets a rebuilt unit then how does one then balance the engine?
Any responses from those who have gone through this experience would be appreciated as I plan on removing the damper once the driving season ends.
Chris.
