The thread is a year old, but I finally figured it out, along with a couple other problems I kept having.
I logged my data and it would always come back with strange LT/ST fuel trims. The car ran OK, so I never really thought much of it, until the cruise control started giving me trouble.
Then I noticed my fuel pump was whining. I replaced it. Since I don’t get a chance to drive the car that often, I don’t put too many miles on it and it was weird that I already burned through a pump. Then that second pump went bad after about 20 miles.
These were cheap pumps mind you, so I figured OK, I’ll try one more time… but I’m going to replace all the fuel filters first. The filters were all fine, the lines were all fine, clean gas.
But I did get to thinking about my data; the LT/ST fuel trims only were problematic when the car was accelerating and under load.
I purchased a fuel pressure gauge from Harbor Freight; sure enough, at idle, the pressure was fine… but I decided to tape the gauge to the window and took the car out for a ride.
Ah Ha! I was getting pressure drops under load, which coincided with the cruise control dropping out. I assume the LT/STs went haywire due to the pressure drop. Because the OBD1 system does not have a trip code for low fuel pressure, I never threw a code.
Now to figure out why I was getting low fuel pressure… and this was 1 of 2 things, or so I thought. Fuel pressure regulator or bad pump.
I had a brand new pump on there, so it couldn’t be that. I had a spare fuel pressure regulator and swapped it on to see if it made a difference, and STILL kept getting the same problems.
Right when I was about to give up, I remembered something - the fuel tank.
About 10 years ago, I had sealed the drivers-side fuel tank with a Por-15 gas tank sealant. I thought to myself, hmm… I wonder if I clogged something with the sealant. So I did a little poking around. And found my problem.
Drumroll…
There is a small piece of rubber fuel line which connects to a metal line, which then connects to another rubber line in the trunk which then goes to the tank switch module, then fuel pump, then lines, etc. The FIRST piece of rubber line, going from the nipple on the tank to the metal line which goes into the trunk had been KINKED.
the tank either shifted slightly (the wedge shim must have moved) or the hose had softened over the years and kinked. This caused a fuel starvation issue with the pump, which is why the pumps kept going bad.
Anyways, long post… but just in case this happens to someone else (weird LT/ST readings coupled with fuel pump failures), check this area to make sure the rubber hose from the tank to the metal line is free from kinks. You can’t see it unless you go under the car - it’s hidden in the gas-tank well.
