My driver’s window has always been a bit slow at the end. Well, recently it will suddenly stop working, and then suddenly one day work again. I checked switch, everything looks fine, motor is getting a good +/- 12V.
I discovered this in Kirby’s Book, and sure enough, when I tapped the motor with my fist, the window started working again.
So I will look at the bolts, but does anybody have any photos or more info on exactly which bolts? The description in the book is a bit abstract. Thanks!
The Book, Page 610 :
1988-89 ELECTRIC WINDOW MOTOR FAILURES: On the ‘88-89 Delco units, the housing on the motor itself gets loose and jams the rotor, or lets water in. Victor Naumann says, “I have replaced a lot of motors that the back has fallen off of and water has ruined.” Steven Draper reports, “After taking the door apart, I noticed that the case on top of the window motor that holds the magnets is held on by only two bolts. The rear bolt had slipped some, and could not be tightened completely because of
the soft metal. The bit of play between that casing with the magnets and the internals of the motor that spin about was enough to cause the motor to only work when you beat the side of the door. I inserted a slightly larger bolt with a nut on the bottom. I was able to put the new bolt in without taking the motor out. Believe it or not, the window now rockets up and down. If you’ve got a window that doesn’t want to go up and down and tapping on the door helps, this could be your problem.” If you can’t find a suitable long bolt, consider threaded rod with a nut at both ends.
