In a message dated 3/8/00 6:05:59 PM Eastern Standard Time,
clive@globec.com.au writes:
<< My 3.07 diff is really getting on my nerves. The car’s just too slow
off the line.
Clive, Does your '65 gearbox have the 2.68 : 1 1st gear ratio or the later
2.93 :1 ratio. I recall Dan and Tony having a discussuion some time back
that the first gear ratio times the rear drive ratio must equal 9 to be
satisfactory. The later first gear ratio does that, the earlier one does not.
FWIW your solution may be a change in gear box ratios rather than
differential ratios. Maybe Dan.Tony, Tom or Terry can best answer this
question.
John
Jagman70
70ots
My gearbox has the 2.68 first gear, so the 2.93 first-gear box, as
fitted
to the Series 2’s, is also a possibility. However, I think I’d prefer
the closer ratio between third and top gears in the Series 1 gearbox…
The Series 2 ratio drop from third to top is 28% whereas the Series 1,
which I now have, is only 21%. (By way of a further comparison the JT5
ratio changes 25% from third to top.)
Clive Arnold
Brisbane, Australia
65 FHC, 1E20761----- Original Message -----
To: e-type@jag-lovers.org
Sent: Thursday, March 09, 2000 2:33 PM
Subject: Re: [E-Type] 205/60 R15 Tyres for the E ?
later
back
be
does not.
question.
John
Jagman70
70ots
I once hit a dip at speed and bottomed the tailpipes with the standard
tyres, so this is certainly a consideration.
I think I’ll try to get some good second hand tyres first and give the
idea a try.
Clive Arnold
Brisbane, Australia
Sent: Thursday, March 09, 2000 11:45 AM
…can you say “drag bottom”?
I knew you could.
LLoyd (A friend has muffler dragging problems constantly)
Clive Arnold wrote:…
Any Listers using 60 profile tyres on the street? Comments
please…
