I am restoring my 1970 E Type and would appreciate it if someone
could send me a link or a photo with the wires connected to the 8
Pin connector for the bonnet. I am using all new harness, wiring
block and 8 pin connector. I also could use the wiring connecting
block. The wire diagram does not address the layout.
In reply to a message from Spartan2010 sent Mon 31 Aug 2015:
Fred, Go to Coolcat.Corp, and in the FAQ section find the
SII ‘‘E’’ wiring diagram. Down in the LHS bottom area you will
see double circles with a number in the centre…these are
the positions on the bonnet connector plug.–
Fred
Spartan2010
John M Holmes 1973 E Type SIII Supra 5Sp, 70 SII OTS 05XJ8L
Ontario, Canada
Thats right you don’t…BUT you DO see each of the
individual connections shown with a double circle…and the
pin numbers are marked on the bonnet female face plate.–
In reply to a message from John M Holmes sent Mon 31 Aug 2015:
Just checked…the circles are single…and the pin number
in black are marked .Look around the diagram till you ‘‘see’’
all 8 of them.–
Ontario, Canada
another attempt I made to document this connector here:
The pin-out is:
Pin 1 - Ground - Black
Pin 2 - Hi Beams - Blue/White
Pin 3 - Low Beams - Blue/Red
Pin 4 - Horns - Purple/Yellow (Series 1 only)
Pin 5 - Side Lamps - Red
Pin 6 - Fog Lights - Red/Yellow (optional)
Pin 7 - RH Flasher - Green/White
Pin 8 - LH Flasher - Green/Red–
Thanks,
Fred
john carey : (888373) Bettie IV - my '63 S1 FHC
Los Gatos/California, United States
In reply to a message from john carey sent Mon 31 Aug 2015:
Ooops, my old photo album showing this can be found by
searching for ‘‘Bettie III 8 pin’’. Others will turn up with
a search string of ‘‘8-pin’’.–
