Can someone please refer me to where the bolt sizes specified in the parts
manual can be decoded? (I need to know the correct length primarily-but it
would be nice to be able to read the sizes!)
Thanks, Mike Moore
Thanks, Mike Moore
would be nice to be able to read the sizes!)Thanks, Mike Moore
One of the list members put together a nice excel file that translates
jag part numbers into numbers you can take to the hardware store.
It can be found at http://www.e-type-lovers.com/memberfiles/bolts.xls
George Cohn
'70 OTS
Thaks George-That’s exactly what I was looking for-and why I LOVE this list
group!
Best Regards, Mike Moore (happily making up his harddware list tonight)
In a message dated 2/26/02 6:51:01 PM Pacific Standard Time,
gwcohn@mindspring.com writes:
George Cohn
'70 OTS
George,
I am stumped by " BD.13565/3" This is the setscrew which attaches the front
door hinges to the body.Can you help translate this for me please?
Thanks, Mike Moore
Mike,
I’m going from memory, but I think those are standard 5/16" NF bolts but
with a pointed end. I think the ones that hold the hinge in the door are
more special and have a taper on the underside of the head -you’d
probably have to get those from a Jaguar supplier.
Clive Wilkinson,
'62 Coupe.
MMoore8425@aol.com wrote:->I am stumped by " BD.13565/3" This is the setscrew which attaches the front
As I recall from past sad experience, any fastner parts that start with a
“BD” index are in the oh-oh category: generally they are non-universal
bits, with some specialized geometrical spec, not to be found in any
hardware store. Which means you have to find another blasted copy of the
exact same piece of hardware. Good luck!
Mike----- Original Message -----
To: e-type@jag-lovers.org
Sent: Tuesday, February 26, 2002 11:38 PM
Subject: Re: [E-Type] Bolts sizes
gwcohn@mindspring.com writes:<<
jag part numbers into numbers you can take to the hardware store.It can be found at http://www.e-type-lovers.com/memberfiles/bolts.xls
George Cohn
'70 OTSGeorge,
front
door hinges to the body.Can you help translate this for me please?Thanks, Mike Moore
exact same piece of hardware. Good luck!Mike
Quite often, these were regular a part with some special characteristic,
like a pointed end to make lining up with captive nuts easier. They can
usually be made by modifying a regular fastener.
I think the ones he was asking about have a tapered head to align the
door hinges, definitely a special part unless you have a lathe to turn a
regular bolt.
George Cohn
'70 OTS
In a message dated 2/28/02 5:04:03 AM Pacific Standard Time,
regular bolt.
George,
I just ordered a new set of door bolts. According to Tom at SNG Barret, the
bolts connecting to the A post (what I need) are pointed. The ones which
connect the hinge to the door have the tapered head.
Best, and THANKS for all the help!
Mike Moore
