In reply to a message from Big Cat sent Tue 26 Aug 2008:
The original battery in this clock was model MR50, or
equivalent, which was a mercury oxide cell producing about
1.35v. Mercury cells have since been banned due to
environmental concerns. Alkaline replacement cells are
readily available and produce 1.5v, like the AA or AAA cell
solutions recommended by others here.
There are some replacement cells of other composition (e.g.,
silver oxide, zinc-air, etc.) that are closer in voltage to
the old mercury cell, but are pricey, less available and not
necessarily required for the unsophisticated clock mechanism.
Also, there is a commercially available converter in the UK
(MR-50 Adapter. Replacement for PX1, RM1, H-P or MR50 discontinued Mercury cells.),
that uses a #357 silver oxide cell, but is very pricey
delivered in $US.
With regard to home made converters, polarity is a concern
because the original cell ‘‘button’’ end was negative, not
positive like most other dry cells. The positive end of the
installed cell is connected to chassis ground through the
clock body. In other words, you have a positive ground
clock with an isolated power supply, in a negative ground
car. Therefore, any conversion circuit to reduce the
+12-14v car system voltage also would have to convert
polarity so that its output was NEGATIVE 1.3 to 1.5v with
respect to the negative chassis ground of all cars for which
this clock was original equipment.
Therefore, I believe the simplest solution is the 1.5v
alkaline replacement cell. It is model #PC1A, or equivalent
(e.g., LR50, PX1A, 1A, 1100A, V1PX, EPX1, etc.) and is
readily available at full source battery suppliers, Radio
Shack (#23-9011) or regularly on eBay. Good luck,–
Has anyone found a battery for the dash clock, installed in a 69
2+2, I was informed that the battery was a 1.5V but I am not
sure. has anyone any idea’s beside changing it to the 12V that
needs to be modified to fit the dash board. ?
Kent
