Dave,
I forget what year your car is, but here’s a nice upgrade
you can do while the engine is apart. Only useful if you
have an early car with the window in the bell housing
back by the dipstick.
First, make sure the factory TDC mark on the flywheel
is aligned with Cylinder 1 TDC – the flywheel can be
installed 180 degrees out, no problem, but then that mark
is not there to find TDC accurately. Use the TDC check
to verify that it is exactly accurate for TDC.
Second, align the damper with that TDC mark, then turn the
engine to 10 degrees BTDC, and mark the flywheel at that
position with a chisel.
Measure flywheel circumference and divide that by 360, to get
the width of a single degree. Then you can use that to mark
individual degrees as far out as you like. I have 40 BTDC
and 20 ATDC, just to cover any eventuality.
That way you can check timing from the top of the engine
rather than laying down on your back. Also, you can be
assured of accurate TDC. You do have a lot of parallax there,
but it’s not to hard to find where to position your head to see
the right mark.
I know, modern timinng lights allow you to dial in degrees BTDC,
and electronidcs are very accurate for that – but the mechanical
switches for seting the advance are very tacky, and I don’t
really trust them. This way I can be sure.
Pretty easy to do while things are apart, impossible once it’s
buttoned up.
Jerry
Jerry Mouton '64 E Type FHC “Laissez les bons temps rouler!”
Jaguar Owner’s North American Tour - http://jonat.org
April 15, 2004 - July 4, 2004----- Original Message -----
To: e-type@jag-lovers.org
Sent: Wednesday, March 31, 2004 4:33 AM
Subject: Re: [E-Type] Oil to my Cams
In reply to a message from Ray Livingston sent Wed 31 Mar 2004:
I have that same tool Ray. Amazing amount of money one can ‘‘waste’’
on Jag trinkets.
I was going to borrow a degree wheel and double check open & close.
Stared at the vernier adjustment in the sprockets for a while. Do I
really want any of that loose near the ‘‘elavator shaft’’ to the
bottom end? Hmmmm. Could be driving in October again!Dave
David Ahlers
Skaneateles, NY, United States
–Posted using Jag-lovers JagFORUM [forums.jag-lovers.org]–Search the archives & forums - http://search.jag-lovers.org/
