I’d like to contribute a unique problem / solution to the e-type
library. About time I could contribute something rather than just
suck on the brain trust.
Lester - you may remember that I was frustrated with my ignition
system, thinking I had a couple of cylinders that had weak spark.
Well, that wasn’t the problem.
As background - I rebuilt my entire engine about 18 months ago -
pistons, valves, etc. and had sent out my carbs for a rebuild. Joe
Curto had at that time about a 4 month waiting list, so instead I
sent them off to a guy in Ohio, who did a good job replacing jets,
needles, etc.
However, the engine never seemed to run well, with the front two
cylinders in particular having heavy carbon deposits on the plugs.
I had also installed a Pertronix unit, and I was suspecting that
this was malfunctioning. Anyway, long story short, out of
exasperation I took the car to a jag specialist I know in
Minneapolis, and he puzzled over it for quite a while. He felt the
front carb (Stromberg 175 CD2 SE) was running rich. The rear carb
was perfectly tuned. However, both were set up precisely the same,
and he carefully measured jet height, needle profiles, etc. and
everything was the same. But one carb was rich, and the other
wasn’t.
He put the engine on the scope, and the ignition and timing was
perfect. So he went back to the carb again, and this time he
disassembled the cold start valve (choke) and noticed that the
surface of the disk was pitted - not severely, but enough to cause
him to swap in a different disk. And sure enough - that was the
problem! Evidently the pitting was allowing more fuel to sneak
past even with the choke closed.
I don’t remember seeing anything in the archives about this, so you
can this to your list of things to check if your Strombergs are
running too rich. I’ll be posting a photo showing the pitting in a
minute, and will add a link shortly.–
Tom McCanna 1969 2+2, 1995 XJ6 Minneapolis
