Hello All, I’ve been getting some domestic pressure to fit
lap-sash style seat belts in place of the existing lap belts
in our coupe. I have sourced belts from XK’s, including a
fitting kit and instructions and will have to make a
reinforced hole in the sill beneath the rear windows. Would
be interested in any observations and photographs that may
assist.
Thanks in advance, Paul–
Paul Breen
Sydney '62 E FHC, '72 ,XJ6 swb, Australia
In reply to a message from mouton sent Sat 4 Jun 2016:
Hi Jerry, thanks for that! I haven’t made it that far yet -
they just arrived. That would indeed be ideal. Mine’s
October '62 - will advise. Regards, Paul–
Paul,
Just a check, but they added shoulder belt fittings there st
starting Feb, 1962 at FHC 860113/885318, it says here. Not on
on yours?
Jerry
Paul Breen
In reply to a message from Breen60 sent Sat 4 Jun 2016:
You should be good. Mine had a decorative escutcheon where
the belt mounts, but you would have noticed it I guess, or
maybe it’s under the cantrail… The mounts make the whole th
thing easy.
Jerry–
Jerry Mouton '64 FHC 889791 ‘MIK Jaguar’
If you don’t have the factory mounting points as per
Jerry’s recommendation let us know and I’ll take some
pictures of mine when I get the car back next week. Enough
of the interior trim is out that I can easily take some
pics for you.–
John Walker, 1969 E-Type Coupe
In reply to a message from John Walker sent Sat 4 Jun 2016:
Jerry/John - found the factory point, just need a spacer to
‘‘stand off’’ through the trim as correct bolt provided in the
kit. Thanks very much for your assistance, Paul–
pics for you.
Paul Breen
Paul,
Here is what my mounting point looks like with the interior
panels removed prior to installation. The clip that was
supplied in my aftermarket seat belts was too large (wide
shouldered) to fit up close to the mounting point without a
spacer too, so I used some standoffs of the proper
diameter. I have been warned that the mounting bolts may
come loose in a major collision due to the leverage they
could apply to the mounting points, so I researched and
found smaller clips, but to sew them into the seat belts is
a specialists job and no one will take on a modification
job like that - at least the ones I’ve talked to. SO I
recommend that you seek a seat belt kit that has the proper
small clips at the third point to enable the mounting to be
done without a standoff of any significant length.
good luck,–
assist.
Paul Breen
john carey : (888373) Bettie IV - my '63 S1 FHC
Los Gatos/California, United States
In reply to a message from john carey sent Sun 5 Jun 2016:
Hi John, I have pulled back the trim and found the holes
and welded nuts. My car has no spacer through the trim as
your’s appears to have. The XK’s kit has a small spacer -
so I will see how that fits up. Thank you for the photos.
I’ll send some back to you - in case they are of interest.
Regards, Paul–
Paul,
Paul Breen
The mount point is in the centre of the picture.–
Andrew B. '67 S1 & S1.5 FHCs,'64 S1 OTS www.projectetype.com
Adelaide, Australia
