In replacing my exhaust (which I did before 18 years ago!), I find the
two halves of the pipe clamp connecting the front pipes to the down
pipes have regular split lock washers and regular nuts. Yet, the manual
warns that these should not be overtightened and the use of the sealing
rings (olives) suggests some movement anticipated as the exhaust moves
up and down.
The Parts Catalogue appears to show the use of one flat washer and nylon
lock nuts here but, will the nylon stand up to the heat?
Gene Williams
74 O2S–
PLEASE NOTE CHANGE IN Email Address to:
@Gene_Williams
Want to see where Gene Williams lives? Go here:
http://www.wintergreenresort.com/
Gene,
The locknuts that would go on an exhaust would be the split or
crimped steel locknuts…
In my experience VW is the only manufacturer that does this…
Every other car that I have worked on usually has brass nuts, not locknuts,
or regular steel ones for the manifold to headpipe…
Cheers,
jebFrom: “Gene Williams” genemike1@earthlink.net
Gene,
No. It’ll melt right out of there. Ask me how I know
pauls 67ots
up and down.
Gene Williams
74 O2S
<<<<<<<<<<<<From: Gene Williams genemike1@earthlink.net
Subject: [E-Type] Nylon Lock Nuts for Exhaust?
Gene Williams
74 O2S
Hi Gene
There are split top lock nuts available one brand is known as Aerotight. You
can guess where they cam from.
Mike Clarke
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager.
No, my guesser isn’t working well! Where do/did they come from?
Gene
Mike Clarke wrote:> The Parts Catalogue appears to show the use of one flat washer and nylon
Gene Williams
74 O2S
Hi Gene
Mike Clarke
@Gene_Williams
Gene
can guess where they came from.
Sorry Gene,
These split top nuts were used in the aircraft industry long before nyloc
became available, probably in the early 70’s from memory.
Anyway if you look up “Industrial fasteners” in Yellow pages and ask a
supplier for these I am sure they can help. They will probably send you a
few a free samples, just quote the thread size, 5/16" UNF probably but check
this.
regards
Mike Clarke
Truechoice in the US has Kay nuts aka Jet nuts which are metal lock nuts good to
450 degrees F. 5/16-24 are $.50 each. Part # MS 21041-5
1-800-388-8783 or www.truechoice.com
No affiliation, etc.
Al Bell
Mike Clarke wrote:> No, my guesser isn’t working well! Where do/did they come from?
Gene
Sorry Gene,
this.
regards
Mike Clarke
Thanks! I ordered them to see what they are but, what would be the heat
limitation? Where did you get that figure? Do you mean that the metal melts at
450 degrees?
Gene
Alistair Bell wrote:> Truechoice in the US has Kay nuts aka Jet nuts which are metal lock nuts good to
Al Bell
Gene
Sorry Gene,
this.
regards
Mike Clarke
@Gene_Williams
Don’t shoot Gene, I’m just the messenger! The catalog is where I got the figure.
I am guessing that at that temperature, the metal expands enough to negate the locking
effect. Either that, or they are made of paper and catch fire at Fahrenheit 451.
BTW, they say Nylocks are good to 250 degrees F.
Al
Gene Williams wrote:> Thanks! I ordered them to see what they are but, what would be the heat
450 degrees?
Gene
Al Bell
Gene
Sorry Gene,
this.
regards
Mike Clarke
