In reply to a message from Ole-XKE1974 sent Mon 5 Jan 2015:
OK, got it, thanks.
Jaguar used no relays for the overdrive and the standard
wiring is no heavier gauge than, say, sidelight/rear light
wiring. I just used the top gear switch to limit
engagement to that gear and force overdrive drop-out once
I went to any other.
With a push-button I can see the logic of a lamp I guess,
although since it’s only ever possible to be engaged in
top, and the rev/speed difference is pretty clear in that
gear, I never felt the need.
My problem on my first D-type replica was having wired to
be usable in any gear, which was all very well until you
forgot it was in use and reversed the car. I did that
three times, very briefly, but the overdrive survived
(which was a pleasant surprise and NOT recommended!).
I look forward to seeing you car some time. As you say,
the wire should be totally unobtrusive with a decent
length stick and matched gaiter.
Pete–
The button is just providing a pulse to the Volvo OD relay
to operate it. A second pulse will disengage the relay.
Because the relay has the relay engaged as default, I needed
an other relay to invert that, which is also able to handle
the peak current drawn by the solenoid. The 4th gear switch
simply cuts the ground to the Volvo OD relay. I am using
the ground to switch it off to get the disengage function
when leaving 4th gear. Unfortunately there’s a short period
when the ground is connected through the 4th gear switch
where the relay is connected to ground very shortly before
engaging, which would cause the power relay to briefly be
1E75339 66 D, 1R27190 70 FHC, 79 S2 XJ12L
Gaithersburg, Maryland, United States
