I’m assembling my pedal box before mounting into the car
and am wondering if anyone has a rough idea of the degree
offset of the brake actuating arm to the pedal. I realize I
will probably have at least one correction after mounting
the hydraulic cylinders but, who knows, I might get lucky.
A quick archive search mostly dealt with where the pedal
should be positioned, not how to accomplish this.
Thanks–
Gary Brinker - 1E11523 66 OTS Mid Restoration - Maumee, Ohio
Gary,
I’m in the middle of a major refurb of my car and I have the pedal
box, still fully assembled and as yet untouched, that I could take
some pics of and send them to you if you think that would do any good.On Wed, Jul 9, 2014 at 4:48 PM, gbrinker gbrinker@parrottalk.com wrote:
Thanks
In reply to a message from Les Halls sent Wed 9 Jul 2014:
Hi Les,
That would be helpful if it’s not too much trouble One view
from the right side showing the pedal and the actuator link
would be great.
Thanks–
In reply to a message from gbrinker sent Wed 9 Jul 2014:
Gary,
Mine is positioned just right – when the brakes are
applied the pedal is just right for heel-and-toe. I took a
wild guess, and as you said I had to open it up again to
reposition. I didn’t have to disassemble everything
though, just enough to move the shaft out past the splines
and then back in.
Jerry–
Jerry Mouton '64 FHC 889791 ‘MIK Jaguar’
In reply to a message from PeterCrespin sent Wed 9 Jul 2014:
Gary,
You might want to set the pedal as far into the footwell
as you are comfortable with. It improves the relationship
between accelerator and brake. You can achieve a similar
result by shortening the push rod. I cut about 8mm off
the push rod and put a 12mm spacer behind the clutch
master which gave a lot more room in the footwell for
increased comfort as well as heel and toe shifting.–
Gary Herzberg, 63 3.8 FHC 66 Series 1 OTS, 98 xk8
Montana, United States
Don’t put the pedal too far down. When I put mine together
the M-C push rod was not returning all the way, locking the
brakes after a couple pushes. For a short-term fix I
shimmed out the M-C. Come to think of it, those shims may
still be in place…–
Jack Terrick 66 FHC
Greensburg, PA, United States
