In reply to a message from Les Halls sent Sat 14 Feb 2015:
Les,
Going rich on deceleration isn’t the concern,
deceleration, like idling is a waste of fuel anyway. The
big issue is what happens on accelleration, namely leaning
out.
Based on my experience, mostly with 2 carb saloons, but
the physics stays the same:
With the car level on a flat surface, all things being
otherwise equal and correctly adjusted, the fuel level in
the jet tube should be more or less the same, but it isn’t
all that critical an issue. AFAIK, a 7/16 float lever
setting equates to about 1/4’’ below the bridge in the carb
throat. Yes, there will be a difference because of the
mounting angle of the engine.
If your fuel level is set too high, the fuel _will_
leak out of the jets where the float bowl is FORWARD of the
carb if you park nose uphill, or out of the jets where the
floatbowl is BEHIND the carb if you park nose downhill.
Similarily the mixture on each carb will tend to
richen/lean when accellerating or driving up an incline or
decellerating or driving downhill.
Having said that, I thought that the rearmost cylinder
(s) on the XK tended to run hot… why would they mount the
float chambers so that the rear carb leans out while
accellerating? Wouldn’t it be better to mount the rear carb
bowl so that it would tend to go rich under WOT?
As the Saloons have a balance hole in the intake
manifold which connects both plenums together the issue
isn’t as pronounced as it would be on an isolated carb
setup like the E - a Saloon will run fairly happily with
only one carb delivering mixture, albeit not very
efficiently, nor for an extended period, but it will run
and even be driveable.
Andrew–
So, under deceleration then…again, flat surface…the rear
carb will tend to go rich and the front two tend towards lean…why
doesn’t this cause a problem…maybe because with little or no
vacuum the needles are pretty much closed and so any additonal fuel
will be minimal…and perhaps there’s enough fuel/air mixture
1968 3.8S
Zurich, Switzerland
