In reply to a message from Les Halls sent Fri 13 Feb 2015:
Les,
You Weber guys wouldn’t know ; -) but the SUs are
configured with two float bowls in front of the carbs, one
to the rear. I believe this setup is to try to balance out
tilt and acceleration effects. So, the front two carbs
will have a somewhat lower jet fuel level, the one in the
rear would have a somewhat higher level if the rear sits
high. Going uphill or accelerating, the opposite would
happen.
Right, because the float bowls are completely separate and
controlled by the needle and seat and float rather than
anything happening to the other carbs, difference in height
would make no difference. Angle of the top surface of the
fuel would, though, quite apart from height difference.
The top surface of fuel in the jet is collinear with the
top surface in the bowls; liquid does not care about the
shape of the container. So if the bowl leans, the surface
of the fuel takes an angle, and the level in the jet goes
up or down a lot more than the fuel at the edge of the bowl
(Actually the vacuum of the carb will always pull the fuel
out of the jet; the level I’m talking about is the level
that would be there if there were no vacuum. The higher
the level, the more fuel flows out at a given amount of
vacuum. The lower the level, the less flows = leaner
mixture)
And again, higher stance in the rear would result in such a
small angle at the carbs that I figure the effect would be
minimal because of that. Not so minimal in the case of
acceleration or hills, though. I have not calculated the
angles, but imagine holding a glass of water on the console
as the driver ran through the gears flat out then braked
hard. Spill, yes indeedy!
Jerry–
‘’…The level in the bowl is
one thing, but the height of the fuel in the jet is
affected by a fore/aft tilt the car might have. Rear high,
the rear carb would be a little higher than the others –
when it’s parked. But your rear won’t be more than an inch
or so higher than the front, will it? The angle will be
tiny, and have little effect…‘’
Jerry, given that all carbs will be at the same tilt angle, then all
carbs would be effected to the same extent wouldn’t they? And the
difference in height (not tilt) of one carb over the others, given
that they are on the same plane, level or not, would not be an
Jerry Mouton '64 FHC 889791 ‘MIK Jaguar’
