I am trying to check my valve timing after doing an upper/lower
chain replacement. First, my car is an early '69 with the
timing indicator bolted to the pan. At this moment I have the
distributor rotor pointed approximately to the firing position
for the #1 cylinder. I have checked the cylinder for TDC (yes,
I know that #1 is the one next to the firewall) and I have the
cam setting tool properly seated in its slot on the driver’s
side cam. The only issue that I have is that the timing pulley
is showing its markings on the driver’s side of the engine
facing the left wheel instead of facing the floor i.e. at 3
o’clock instead of 6. I did find an excellent tutorial on
checking the timing over at Harvey’s Newhill Garage site and
following that, I am now stumped. He did mention that later 4.2
engines had their timing markers on the side of the engine,
although I have no idea about what constitutes ‘‘later’’.
So, do I have everything lined up correctly for the cam tool to
register properly? Could I have a ‘‘later’’ engine and am just
missing something? Does anyone have any expertise in this area?
Thanks,
Bob–
'69 2+2-Big Red, '69 OTS-Priscilla, '99 XK8-Othello
Mantua NJ, United States
