1970 E-type SII OTS Cannot find the torque specs. for the 2
cam bolts that retain the camshaft sprocket. After torqueing
I will install safety wire.–
Dales 1970 E-type OTS
In reply to a message from dale1937 sent Sun 23 Oct 2016:
I make sure male and female threads are clean using brake
clean. Then a little locktite, then pretty darn tight, then
careful wiring with lockwire–
Dennis Vancouver Canada 69 Roadster
In reply to a message from Dennismo sent Mon 24 Oct 2016:
Thanks for the response. Question is how tight on a torque
wrench is pretty tight?–
In reply to a message from dale1937 sent Mon 24 Oct 2016:
Dale,
In the absence of anything else, I just look up the recommended
torque spec for a fastener of that diameter/thread pitch/material
grade in one of the many tables available on line.
-David–
In reply to a message from davidxk sent Mon 24 Oct 2016:
Thanks for the comments on torque for the cam plate on the
front of the cam. I sure do not want to break that bolt
which would require removing the cam and drill out.–
