I have a weeping ribbed valve cover (non chrome cover). The “tears of
oil” comes out between one of the valve cover studs and the valve cover.
Does anyone have a fix worked out for this problem?
TIA,
Will
Weeping in Rocklin CA
TIA,
Will
Don’t start the motor!
Wade
70 FHC
72 2+2
In a message dated 12/18/98 8:29:05 PM Pacific Standard Time, V12CLAWS@aol.com
writes:
<< Don’t start the motor! >>
or don’t put oil in it…
Pull off the cover inspect for cracks , set a straight edge on mating
surface and use new copper washers
.Daniel
7Star Computer Solutions wrote:> I have a weeping ribbed valve cover (non chrome cover). The "tears of
oil" comes out between one of the valve cover studs and the valve
cover.
Does anyone have a fix worked out for this problem?TIA,
Will
Daniel’s @Daniel_Sandoval
Fine Automobile Service Austin, Texas
http://www.geocities.com/MotorCity/Speedway/8200
Daniel,
Thanks for the reply. The problem turned out to be a bad copper washer
that the PO had “corrected” by adding a rubber O ring under the copper
washer in an attempt in an attempt to stop the leak. Needless to say,
the O ring had gone to pieces and allowed the weeping to occur. One new
copper washer is in order.
Season’s Greetings,
Will
64 S1 FHC
68 S1.5 2+2
69 S2 FHC
Will
I had the same problem and used the plastic washers that are used for
V12 cam covers, instead of the brass washers. Success was 100% and much
less torque needed to tighten the covers down. If you do not want to use
the plastic washers you could coat both sides of the brass washers wilh
non hardening gasket goo.
Dennis
69 OTS
Will
