I need an early ribbed cam cover, to utilize a mechanical cam drive. Need not be pretty, but scruffy since its going on the rat rod.
If you want it, you can have it but you will have to organize UPS / or FEDEX to collect, the cam cover that is !
The later closing plate has a grove to accept a smaller O ring , but the threaded closure to accept a tachometer drive does not have enough “meat” to machine in a groove, so I machined one in brass for my 120.
Do you intend counterclockwise for the tachometer or will you fit a reverse gear adapter?
I am soon to fit a series3 XJ6 3.4 engine to my 68 240, I have smooth covers to fit so the XJ6 and if I still have them the 240 ribbed covers will be available, but I do not know if they are what you need, Epping Essex, Pat
