Need to ask question as to how thick a flat washer should be on engine mounts.Have two rather thick flat washers that can’t recall where they where removed from. They are about 1 inch diameter and fit over the studs but seem too thick at about 1/8 inch. Memory has failed me.
Know some of you have removed the front suspension resently and hope you can help me out.
This is the engine mount where washer size was asked about. The two larger and very thick washers do not go here. Those are for the shock absorbers.
Installed flat washer, lock washer and nut on both engine mounts. Tight fit for big hands.
Sorry for the dumb question.
Brain freezes happen to everyone, you aren’t the first and certainly won’t be the last
