Facts and Fiction regarding interchangeability of Facelift Coupe and Convertible Windshields
My Wife’s ’92 XJs is physical proof that a windshield from a ‘94 convertible will fit a ’92 Coupe. I had contacted Grundy Insurance and complained of delamination on the right edge of the OEM windshield and micro pitting that made it near impossible to see facing into the Sun. They agreed that the windshield should be changed and assigned the job to Safelite. Safelite contacted me in the next couple of days and stated that they did not have a direct replacement for the OEM Triplex windshield, but would begin a search to find a suitable replacement After about three weeks, Safelite called and said they had one that they believed would fit. I asked them if it was of the same shape, dimensions, and thickness - they replied Yes, but it had a Rear View (RV) mirror mounting lug bonded to the top center of the windshield, and was intended for a ’94 XJS convertible. I again asked them if all the dimensions were the same, and they affirmed that again. I had read the opinions that the Facelift convertible windshields were not interchangeable with the Facelift coupes. They sent me a picture, and I saw the bonded lug and knew I could remove that with heat – you can see YouTube to see how that is done. So, I asked Safelite to get it, remove the RV mirror lug and install the windshield.
About two weeks later, the Safelite shop called and said they had the windshield in hand, and gave us an appointment time for the install and kept the car for the day. We received a call a few hours later, and they said they had the old windshield out and that we were lucky – there was no rust at the lower left and right corners of the windshield frame – as they were aware that was a problem with many of the early facelift coupes. They also planned to put a rust inhibitor coating in those areas. As well, they stated they were able to reuse the mastic dam, the rubber perimeter seal and the seal expander strip – thank goodness for garage kept cars. I asked the technician if there was any difference in the thickness of the old and the new windshields – he said hold on, he would measure – came back and said the thickness was the same (contrary to the rumors).
The next morning, we received a call that the car was ready. We went to pick it up and were quite pleased with the job – it had a brand new Fuyao windshield that fit perfectly, and they had installed our RV Mirror mounting lug and Gentex RV mirror that we had previously mounted on the ’92 OEM windshield about 8 years ago. It has auto dimming, Home Link for three garage doors, and a compass. We have had the car back for about two months now, and have had no leaks, and have not noticed any distortions in the windshield glass.
In conclusion, I believe there is no difference between the ’92 – ’94 Facelift coupe and convertible windshields except the RV mirror Lug mounted at the top center of the convertible windshield. I suspect that the ’95 – ’96 coupe and convertible windshields are also the same dimensionally as the ’92 – ’94 windshields as well, but have no proof of that yet. Yes, there are differences in the tints, the sealing devices (probably because of the early facelift coupe rusting problems) and the chrome surrounds. To find the answers, can someone provide a picture of the OEM windshield labeling from a ’95 Coupe and a ’95 – ’96 Convertible. Please place a square of white paper on the inside of the windshield behind the labeling to provide a clear picture from the front – see pictures.
AE
