Ignore those comments. The 6.0L does not have the same crankcase venting as the 5.3L
Thanks Steve for clarifying this
I did change the rubber parts on the part load breather system, and cleaned the full load breather filter
Iâll take the AAV out and check it
AAV out (easier than I feared, pumping 4l of coolant allowed to take it off without o mess of coolant in the garage)
and tested ont the âbenchâ (more like SWBOâs kitchen, as I donât have hot water in the garage)
at 25°C, the top of the piston is at 67.2mm from the top of the AAV, and the air gap is open :
at 80°C ish, the piston raises to 63.7mm, and the air gap is closed : ( I tried blowing air through and itâs very difficult to gat some go through)
so time to refit the AAV, and look for air leaks elsewhere
Iâve seen some pressurized smoke machines which look like god send for such chase, but I doubt my next door garage has one
I thought about air getting in the engine and being thrown in the admission by the engine breather : Iâll try and block those ports and see if it makes any difference
I searched for the O2 sensor connectors, and found the right one , the left sould be similar opposite side, but less easy to reach
Iâd done about 40 miles in my 6.0ltr V12 last Sunday & just at the point I removed my foot from the accelerator at about 75mph to slow for a junction, I got an FF36 code. The car wasnât running any differently, at idle or at revs as I drove home.
Iâm thinking Iâve got an oxygen sensor fault due to when the fault code having appeared With a âclosed throttleâ - if the fault had appeared @ 70mph & 2,000 revs, i would have suspected an injector fault. It could of course be neither & be an engine wiring harness problem.
I re installed the AAV, and no surprise , no change, idle is still to high
I blocked the AAV input port in the LH air box, and idle is still 900rpm, no drop in rpm
which makes sense as the AAV is doing its job, air coming from elsewhere
I could hear the air draw on the distributor filter, but wasnât able to locate an air entry
next step will be to replace the remaining vacuum hoses,:
both in and out the distributor (even if they shouldnât make a difference
one from each manifold (rear of the RH side, bottom of the LH side) heading to the front of the engine
Is your distributor cap gasket present? Paperish gasket under the cap.
yes, the gasket is there
I fitted a new one when I got the car 4 years ago (limited miles since, and it still looks ok)
Have you tried spraying carb cleaner around the intake area?
Dang, I had thought by the time Jag got to the 6.0 they had âcorrected the errors of their waysâ in the XJS line, but I guess not, from all the work you had to do on yours.
Hmmmm. So wondering now if this âa.f.t.â is what is responsible for the disturbing sound and feel of CLUNK when engaging the trans in gear (D or R) while idling? She does seem to tend to idle @ 1,000 RPMs, and yet I couldnât figure out why only being about 33%/250 RPMs off could make such a big difference in the behavior of the trans in that regard. btw, what SHOULD our cold idle be on '92 5.3? If the a.f.t. is in fact responsible for the trans issue, how do you clear it out, either temporarily to see if that is whatâs wrong or permanently if it is wrong?
What should our cold idle speed be, Gregmatic?
Do you have a current address for him, Gregmatic? I think someone else mentioned earlier that JohnJohn has some kind of repair kit for the AAV, but I donât see it on his Ebay website. Has he stopped selling those?
You need to contact Jonas (JohnJohn) in a private message for AAV.
Cold idle is very dependent on temperature. Mine is usually around 900-1000rpm, but can be higher on a very cold day. In a hot climate, it could be lower.
I just did (btw, didnât realize Jonas = JohnJohn until now ). Also complimented him on his newest item in his Ebay store (added just 2-3 days ago) - the bad-azz throttle bushings!
no big surprise for me, even being a ânewer versionâ, my car is stil 26 years old
my AAV was rebuilt using Jonas (JohnJohn) 's kit, and I also fitted at the same time a pait of his aluminium half moons and revised banjo bolts
@ Robin_O_Conno
I had a try, but nothing was noticeable : Iâll have another go with the AAV port blocked, as it could help
one thing which surprised was the ability to rotate the injectors with out efforts, even after they were back into their location in the manifolds
The gasket seems to be compressed ok,
I would not increase the torque on the manifolds nuts : I went up to 30Nm
edit :
I 'll have a look at the centre vents piping connections : I replaced all the rubber bends and gaskets, so could have left a loose clip / leaking point on one of those
Well, that ainât right. When you block that opening the idle should drop. Whether or not it drops enough is the question. If it doesnât drop at all, the only explanation I can think of is that itâs pulling all the air it needs through the distributor vent. Which probably means youâve got the idle screw all the way in.
One thing is simple: If the idle is too high, the engine is getting too much air. Either thereâs a leak somewhere, or the butterflies arenât closing like they should.
indeed
I could have saved the AAV removal and testing if I had followed Steve (sbobev) 's suggestion, as the result is exactly the same : blocking the AAV air entry only leaves the Marelli vent as input
I checked the throttle links and removed any restriction to closing the butterflies
the links were a bit short and I loosen them so the butterflies spindles click on their stops
Iâm thinking of closing the partial load breather pipes for a test, as Iâve already checked all the lines coming to the manifolds
eidt : I checked those pipes, and one of them had a loose rubber end on the oil separator
I tried to get a better fit, but Iâm not really glad of it, and the result is the same as before.
Iâll look for rubber bungs to get both pipes closed, and have another test
I think this thread has ran its course. From the last a dozen or so posts, it is evident that people are not reading the prior messages, and there are now repeats of ideas already discussed.
My recommendation - start a new topic with your quest for chasing the vacuum leak(s). Once the culprit is done, letâs come back to the FF34 discussion.
PS 900 rpm with the AAV intake port blocked is a sign of HUGE leak. You donât need a smoke machine for that.
Last year, although I had a good idle at 800rpm, when I blocked the aav and breather to distributor, it would only go down to 600RPM. I spent a lot of time looking for vacuum leaks to no avail.
Finally realized I had incorrectly adjusted throttle body gaps, and they werenât centered correctly. Once I correctly got them adjusted, I had to back out AAV screw a bit for 800rpm. Now when I block off AAV and distributor line, it drops to 300-400RPM.
