Just installed the bonnet after full car rebuild, during which I did not change anything in the wiring.
Now flashers flash on one side, [but not always] but stop flashing and go to steady dim [every time] when I flip the headlight switch [headlights still not installed.]
Wiring diagrams are not my forte. Anyone out there who can help troubleshoot this thing?
Many thanks.
ALL bonnet-mounted lights go off when bonnet is open - i.e. seems like the only grounding is through the positioning latches/receptacles. Weird. Did I miss a grounding wire to the bonnet someplace?
Robin and Chris - you nailed it.
With a little fiddling and scraping, all lights go on as intended.
But interestingly when the bonnet is OPEN there is clearly a lack of electrical connection, but it is solved by running a short wire from bonnet to body. The question is, is there a separate grounding strap to “earth” the bonnet? Did I miss a wire?
NB- the spring/arms are not installed yet - so maybe they will provide the grounding?
I just ran a wire from a bolt on the bonnet close to the passenger side hinge to a bolt on the picture frame. This photo shows the wire I found in place when I bought the car before I refurbished everything ahead of the firewall. It’s not original, but serves the purpose.
It might be a good idea to check all of the grounds in your freshly painted E to confirm good connections. A coating of dielectric grease on each also recommended. Pay particular attention to the main ground strap connections to accommodate the draw of the starter - if inadequate the current will seek ground through all the other, much smaller gauge ground wires in the harness and melt their insulation.
