Dear all,
since this is my first contribution to the forum, I would like to say Hello! to everyone, and a big thanks to everybody for all the useful advice given here. The forum, in combination with the technical FAQ section on the webpage, is a hoard of treasure when it comes to fixing all those charming weaknesses we have to struggle with.
That being said, I today encountered a problem which is completely new to me (16 years XJ6 III, now XJ12 III HE since a few weeks). I am speaking of the following phenomenon (XJ12 III Sovereign H.E. 1983): When I turn the ignition swith to position 2, but without running or even cranking the engine, the fuel pump starts its duty (which is OK), but then won’t stop (which isn’t – it should stop after two seconds). In other words, the so-called Flooding Protection System is down. As this car is relatively new to me, I cannot say wheter this is a new issue or I just didn’t notice it until now.
I already checked the related relays, they are all fine and doing their job. However, while checking, I got puzzled by the following:
Without the pump relay installed, and with a multimeter in its place, the wires of which connected to the signal circuit of the relay, turning the ignition on pos. 2 will produce 12V for about two seconds in the signal circuit (which shoud switch the relay on and off). After these two seconds, the ground connection of the signal circuit, which directly enters the control unit, will be broken (while the 12V are kept – dead end). So, without the relay in place, everything works fine.
However, with the relay installed, the signal circuit will stay stable, that is to say: The control unit will keep the signal circuit grounded, and hence the pump will continue to run – forever.
I already studied the circuit diagrams in the workshop manual, but they won’t help much, as there seems to be something going on in the control unit, which is more or less a black box as seen from the perspective of the manual.
Anybody any clues on this weird behaviour of my fuel injection system?
Best
Florian
