Folks:
I last posted here regarding the potential impact of worn ball joints on a severe pulling problem that my 1990 has developed.
I have been investigating this, and have discovered significant wear on both front tires, but much worse for the driver’s side. The wear is biased to the edge and is down to smooth rubber, while significant tread is left elsewhere. I examined the tie rods while moving the wheels, and I do not see any visible slop in either tie rod connection. This is with the front lifted onto stands behind the front wheels. The steering response is sharp, one-to-one: control input, wheel movement. Of course, there is no friction force that the tires must overcome (with respect to ground contact) to move.
I have to test the ball joints, but visual inspection shows the boot integrity to be solid, and there is no external evidence of lubricant leakage from any of the joints at either wheel.
Some history, and particulars: first, this car has around 97K on it. I have replaced the rack, having done this about 10-11 years ago. I put around 1 to 2K miles on this car per season, it is a fair weather car. When I installed this, I took care to note the old rack’s fixing locations, and the tie rod positions (number of exposed threads on each), and refitted the tie rods and the rack to the same positions as I found the originals.
I did not have the front end aligned after the new rack was installed. It appears that I should have, as when I carefully looked at the front tire position with the steering wheel centered up, neither front tire was pointing squarely ahead- could note deviations by eye, with the passenger side being toed out rather markedly, once I looked carefully at it. I did not recall this when the rack had been changed out; I looked carefully, then, too, at that time. But I did not have the worn tires and handling behavior evidence to suggest a problem, then!
In any case, the direction and degree of wheel direction seems to correlate with the position and severity of wear on the tires.
Also: I had installed poly bushes on the car in the original rack- loved the response- VERY precise, with good road feel. I went through H*ll getting the old bushes out, having chosen to do the job when I had the engine and trans out of the car to do the 5 speed switchover. This enabled good access to the rack, and boy, did I ever need it- getting those bushes out was quite a monstrous exercise. I got the new bushes in, and rebolted the rack, and proceeded to finish the 5 speed switchover- circa 2008 or so, as I recall.
Eventually, the rack tower seal started leaking, and I ordered a rebuilt unit…which came with OEM bushes preinstalled. In my rush to get the car back on the road, I installed it as it came. Big mistake- while the rack was fine (no leaks, that is), the sloppy steering and lack of road feel returned. I really missed the behavior from when poly bushes had been fitted. Oh well. I drove it this way for several seasons, as I just did not have the desire to repeat my experience of getting those bushes out again.
So, I am leading up to a question, now: the Jag manuals, on the procedure for R/R the steering rack, advise to use special tools: one to locate the precise steer center point, JD-117, ‘Steering Rack Centralizing Pin’, and another to locate the rack with respect to the lower A-arms prior to tightening the mounting bolts, JD-36A, ‘Steering Rack Checking Fixture’. I had/have neither tool. I am guessing that the tool that centers the steer point could be substituted for an awl or something similar. But the tool I am interested in is the one that locates the rack with respect to the lower A-arms.
This tool is not mentioned in any significant way in The Book. Have any of you who’ve messed around with the steering rack devised a similar tool? I am looking to do some work on this rack, to ensure it is properly centralized, R/R the bushes (gonna use a commercial tool this time- the one I made according to The Book did not work out well for me the first time I R/R’d the bushes on the old rack), and then centralize the rack/pinion/steering wheel, to get a proper center point, and THEN work to adjust initial wheel pointing and toe settings.
A final note: as an experiment, I put a pair of tires on the front, tires with even wear and good tread (an extra set of 245-50-17’s), and ran the car- no pulling at all. But the steering was terrible- sloppy and awful feel. Matched with multiple posts I found in this list of what the car behaves like when the steering rack bushes are mush. These observations are leading me to believe the problem I have been experiencing is due to two things: 1) improper toe setup of the front wheels (I missed the mark when I installed that rebuilt rack, and the long term wear effects on the tires led to the pulling phenomenon) and 2) the rack bushes are now old enough that they have gone super soft, and need replacing.
I could still have a ball joint problem, and I have to do more checking on that, but I KNOW the rack related issues (toe and bushes) need to be addressed for sure.
One more bit of history on the car: I rebushed the front end completely around 15K miles ago- poly upper/lower A-arm, poly sway bar and end links, and replaced the front and rear suspension cradle mounts as well. New shocks and fresh mounts as well. I do not think the issues I have been experiencing are due to any of these areas, at least at this time.
Interested to hear what folks do, in place of the JD-117 and JD-36A tools!
Thanks in advance!
-M
