Hello
Need to order some fuel line & fittings & need the correct specifications, can anyone help?.
Cheers Peter
Hello
Cheers Peter
The fuel line was 5/16"copper. The fittings probably BSPF [ BSPP]
The correct repro rubber hose connection from pumps to carb pipe is available from Alan Gibbins in UK [very nice]
Your float bowl tops should be the ones with …"… Adderley Park…" cast into the top of them.
And these can often be easily repaired if the banjo bolt thread strips.
Here are some fuel line photos from a '38 2.5L car that may be useful.
46268 Engine.pdf (1.6 MB)
