Curious if anyone has personal experience with a reasonably priced (say sub $100) fuel vapor detector that I could use to check individual connections in the boot. For example, I see this one on Amazon, seems a little too good to be true. Feedback based on personal experiences appreciated!
thx
Bob
You need to calibrate it by turning it on in a clean environment. Then dial its sensitivity in. Once you get the hang of it, it’ll help you find what you’re looking for.
To make a true test you will need a detector with air sampling pump (sucking probed air into the sensor).
You’re looking at approx £150. Otherwise - any cheapo will do (don’t overpay).
