@Wiggles very kindly gifted me an XJ head to replace my scorched, cracked, and pitted original which I deemed beyond saving.
In tearing it apart I found that one of the exhaust tappet guides was thoroughly bashed all around it’s circumference. Interestingly it was now all the way in and not contacting anything, and the cam shows no signs of contact. I imagine it popped out at one time and the previous repair involved bashing it back in without remorse and possibly replacing the cam.
Having my old head with intact guides I decided to rescue one of those and use it to replace the wayward one. It was actually too tight for the bucket, so after a lot of careful sanding the guide ID and checking for interference I had a perfect fit that slid and rotated easily with no discernible play.
Now I wanted to fit it into my replacement head, and to my disappointment it just slides in the hole without any resistance. Of course I should have checked it first (yeah hindsight), but measuring the bashed up guide reveals it is .002" oversize.
A bodge fix such as manually “knurling” the OD of the now endeared-to-me standard guide (I know, I shouldn’t have named it, sorry George) came to mind, but then of course the aluminum of the not-yet-as-endeared-to-me replacement head will be permanently scarred.
So I figure I can attempt to do the following.
- Get an .010" oversize guide from SNG
- carefully hone the head for a .002" interference fit using a brake hone or somesuch
- carefully bash the new guide home
- carefully hone the ID of the new guide for the proper fit of the bucket.
- stake all of the exhaust tappet guides down for better sleeping at night.
I feel like #2 is the most iffy. The hole is not particularly deep to allow for self-alignment of the hone, and being aluminum is may end up oversize in seconds. Using a friends milling machine could be an option, but of course quarantine and whatnot will mean a delay in that. This seems like overkill for sending to the machine shop imo, but maybe I’m being naive.
What do folks think, I feel like using the standard tappet with no interference fit isn’t smart, even with the stakedowns, and bodging it doesn’t seem great though it might be fine. Fixing it the “right way” seems like a pain, but this is nothing new.
Thanks!
