anyone know where the fuse that controls the ABS is located.
Thinking of pulling the fuse #11 ECU
Anti lock acts flaky. Fills better when the ABS warning light is on.
Any issues if I pull the fuse?
Do I need to unscrew the kick panel?
If you leave the panel off I would suggest you at least still leave that aspirator connected to the climate control system and mounted/positioned somewhere fairly close to original location. Otherwise your Delanair Climste Control system may give less than stellar performance.
