.I just received the gasket cork for the transmission oil tray … but I don’t know if I should use some silicon or something to put it in place … if I should use silicon (permatex) … I should put it on both sides of the gasket … ??? thanks for your help … oh and I put a picture of the gasket …any suggestions is welcome…
Cork, dry, not too tight on the bolts (this only deforms the metal and does not make it seal any better) works well for me. I‘m not a huge fan of sealants and my transmission seals well.
It does look like paper!
Anyways the three times I used a cork transmission gasket (two times I actually reused what I had) they sealed fine, put on dry and not very tight.
