Sorry to be a pain and hark back to the old 4spd all-synchro overdrive oil question,
The background is that just about every vehicle to use the Laycock overdrive specifies 30w monograde non-detergent oil, or 20w50 engine oil, or a modern 75w80 GL4 gearbox oil(similar viscosity to 20w50 engine oil - different scales!)
This includes Triumph TR, MG, Jensen 541, big Healey, and Jags with the Moss box (pre 1965 or so)
Those in the know about the overdrive say heavier oils might cause excessive hydraulic pressures, break components, cause the o/d to fail to disengage; or that newer EP friction modifiers might âcause sludgeâ
Nevertheless, it is crystal clear that Jag specify a EP90 hypoid type heavy gear oil for 420, Mk10 4.2, XJ6 series 1 and 2. Obviously not a typo.
It does seem odd,tho. The new jag box doesnât seem to have EP/hypoid gear trains and apparently is nothing out of the ordinary compared with the others listed above (TR,MG,541etc). WHY did they change their specification (hopefully not just to simplify inventory).
So - further questions- are modern âequivalentsâ to EP90 actually safe for components in the gearbox? Thank heavens the old lead-based friction modifiers are gone, but are replaced by GL5 sulfur based agents that are said to damage brass/bronze components
A pop quiz of experts has reaped a mixed bag of opinion. Overdrive rebuilding experts in the UK recommend 20w50 engine oil for our application, classic jag workshops with decades of experience offer advice ranging from 30w mono, via 75w90 GL4 to 80w90 or 85w90 GL5 EP oil.
surely there is a proper answer?
