good morning…I’m having a lot of difficulty assembling the engine in the car.
I need to know where the ground cable should be connected which is fixed on the right frame side member… with left hand drive… behind next to the transmission. A 3/8 large bolt.
Maybe on the starter motor bolts. Do you have an xj12 series 1?
On the six cylinders it goes to one of the lower bellhousing bolts.
