I keep getting error code P0193. Must be accompanied with my heavy foot as it never shows when the wife drives the car. Car is a new to me 2008 XK with about 30K miles. PO replaced the fuel pressure regulator twice (first replacement claimed to be defective) a little over a year ago, so must have been a persistent problem. I am thinking an 11 YO car with only 30K miles must have been sitting at some point creating a shellac problem? Thoughts?
Check/change the fuel filter.
Looking at the code that is for high pressure? If it is then I don’t think the fuel filter is going to cause that, it would be more likely to cause a low pressure reading I would think?
Have a read of this thread, it may help.
https://www.jaguarforums.com/forum/xk-xkr-x150-33/p0193-code-won�t-turn-off-resolved-203424/
Symptoms for that code,
What causes the P0193 code?
- Low or no fuel
- Wiring that is exposed, broken, shorted, or corroded
- Connectors that are corroded
- Fuel filter that is clogged
- Defective fuel pump relay
- Bad fuel rail sensor
