Hi all
I’m fighting getting these off… what should I be doing?
Is that a jag part? My VW has a bunch of those things. They’re call speed clips or something. If the stud is threaded you can spin them off. If not, then pry back on one of the tangs a bit and it will slip off. If it gets bent you can push it back down in a vice.
Thanks Erica. Yes they are on the back side of the radio faceplate on the center counsel.
Use a Hook Scribe to get under the tab and gently bend them outward.
