Bad 3cu ECU can be due to bad Elec. capacitors, open unit and replace them, thats what I did, all OK now
I didānt purchase the car (and donāt plan to now that I know the issues I would be facing)
but to sumāup: the seller has installed an 1990 S3 engine on a 1975 S2 car without changing anything else (same 1975 ECU , original D-Jetronic ingnition, original sensors, harness, etc)
so not surprinsigly he managed to start the engine with spray in the air filters but it only runs for a half a second and dies.
@MarekH went that route, search for his posts, or search for āstand alone ECUā, āaftermarket ECUā it has been discussed many times and there was a recent thread as well.
thanks Aristides
could not find it with these keywords- no worries
Indeed, Rolando - the ignition is an independent sub-system, requiring no ECU or external inputsā¦
Frank
xj6 85 Sov Europe (UK/NZ)
Thanks Frank, good thing
thanks Bill
I like the " If you want to get your hands dirty with engine management" , but in white gloves ?
I donāt believe that with my programming talents I would be capable of leading the way on such an innovative solution
maybe already tested by some forum users ?
