Hello
following my topic on search for donor car VIN for a series 3 engine (here : https://forums.jag-lovers.com/t/reverse-xj12-vin-with-engine-number/433013/26)
which has been solved thanks to active contributors, I am going to the next step which is understanding what implications means the replacement of a Series 2 engine (no more available) by a Series 3 engine (already in the car, which I am considering purchasing)
All mechanical job done , but ECU and electricals not yet switched from S2 to S3: the Series 2 car is still fitted with a D-Jetronic ECU (DAC1936 6CU - AEU1121E) and -no surprise- it will not crank
I am therefore considering replacing this ECU by a more suitable DAC4478 16CU (available as spare) or a DAC6336 (16CU) (which I will have to acquire) which seems the correct one for a NON O2 , 1990 engine (as identified in previous post)
has anyone done it already ?
when looking a the diagrams in respective Manuals (although they alas do not mention which DAC they are based upon), there seem to be significant differences which might be difficult hurdles for me :
1/ on S3 there is a âfuel injector amplifierâ (identified N°292 on diagram, connected to terminals 4 5 14 24 on ECU), absent from S2, on which is displayed a bank of âpower resistorsâ (N°313); how different ?
2/ on S3 , there is a âthrottle switchâ N°310, (linked to terminals 12 14 17 on ECU) which on S2 is named âThrottle potentiometerâ , also N°310, connected to terminals 7 19 20 ; same stuff ?
3/ on S3, a âvacuum changeover switchâ N°360 and a âsupplementary air valveâ N°361 are present, not on S2 âŚ
there are surely be other differences, but these already seem a bit frightening for being able to cable correctly a new DAC 6338 ECU onto a S2 harnessâŚhow much should I worry ?
here are the above mentioned identified on S3 diagram
and on S2 diagrams
