The restoration of the distributor is not particularly obscure and mysterious.
Unless there is something seriously worn such as shaft bearings or cam lobes, it is often just a matter of cleaning, including the felt seal, and replacing the points and condenser, and being aware that the Bakelite saddle, connecting wire and feedthru stud should not ground the moving side of the points, but only the grounding wire grounds the stationary side.
