What’s the wisdom on inlet/intake gasket sealants? My gasket set has a fibre gasket for the intake, but it’s so long since I fitted an intake that’s not on a V8 that I can’t remember if I would usually use a sealant or not. I suspect not, as it’s on the fuel side of things, but thought I’d ask before I get stuck in.
140 SE engine, SU H6s.
As a minimum around the water ports…a thin smear…i like blue hylomar…Steve
Ah, water ports… thanks Steve
I always use spray on copper coat on them. If for nothing else, it helps removal down the road.
On the fibre ones? I had always thought copper spray was for metal gaskets.
Nope… It works on all manner of gaskets.
