Hello,
I wondering if this intake manifold would work on a 4.2L with SU HD8.
It will work on a sedan; it will NOT work on an E Type.
It’s on a 4.2 Mark X/429G now. Will fit your XJ but might require a bit of tweaking to clear the bonnet at the front carb. IMHO.
Thanks for the quick response. Yes, I have a XJC. I just recently purchased Triple SU from a 1964 e-type that need rebuilt and I need a manifold.
Fit should not be an issue for a saloon. Won’t fit an E-type.
Other issue: correct me if I am wrong, but E-type SU’s are not the same as saloon SU’s. E-type is manual choke, saloons tend to have an auxiliary starting carburetor? I think you can see the piping for that in the photo.
Maybe just block those two lines off, and use the E-Type manual choke?
Always double check before you close the hood the first time. Up bumps are embarrassing
